Introduzione
If the LED light in the drill no longer turns on, you can use this guide to easily replace it with a new one.
Parti
Remove the nine 15mm Philips #1 screws Remove the two 12.5mm Philips #1 screws Remove the two 10mm Philips #1 screws
  • Remove the nine 15mm Philips #1 screws
  • Remove the two 12.5mm Philips #1 screws
  • Remove the two 10mm Philips #1 screws
Aggiungi Commento
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
Aggiungi Commento
In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
  • In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
  • The black plastic piece is the housing. The light is placed inside this black plastic housing.
Aggiungi Commento
Pull the black plastic piece up out of the slot in the drill body that it fits into.
  • Pull the black plastic piece up out of the slot in the drill body that it fits into.
Aggiungi Commento
The light itself can be easily removed from the black plastic piece by simply pulling it out.
  • The light itself can be easily removed from the black plastic piece by simply pulling it out.
  • One of the metal “legs” on the LED is longer than the other and it must be placed in the black plastic housing in the same manner it was removed or it will not work.
Aggiungi Commento
Take your new LED and slide it back into the plastic housing in the same orientation as the old LED.
  • Take your new LED and slide it back into the plastic housing in the same orientation as the old LED.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
justin boyd
Membro da: 13/05/2013
128 Reputazione
1 Guida realizzata
Cal Poly, Team 4-15, Maness Spring 2013 Membro di Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 565
