Salta al contenuto principale
Black and Decker BV2500 Type 4 Powerhead Assembly Replacement
Cosa ti serve
  1. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Clamshell (Black Outer Casing): passo 1, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: passo 2, immagine 1 di 2 Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: passo 2, immagine 2 di 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Powerhead Assembly: passo 3, immagine 1 di 1
    • The powerhead assembly is the entire orange part of the device.
    • Replace it with a new powerhead assembly.
Conclusione
Angelica Chow
Membro da: 01/25/14
409 Reputazione
3 Guide realizzate
Cal Poly, Team 9-29, Maness Winter 2014 Membro di Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,184
