Introduzione
This guide will take you through the process of replacing the impeller on the Black and Decker BV2500 Type 4.
Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
  • Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
add action shots
Rhys - Replica
Using your hands, remove the blower tube and clamshell. To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
Aggiungi Commento
Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver. Using your hands, lift off the side of the orange casing with the screws facing you.
  • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
  • Using your hands, lift off the side of the orange casing with the screws facing you.
add action shots
Rhys - Replica
Locate the fan.
  • Locate the fan.
  • Unscrew the 9/16" cap and nut (in the middle of the fan) with the ratcheting socket wrench.
Aggiungi Commento
Carefully use your hands to slide the fan out from the rest of the device.
  • Carefully use your hands to slide the fan out from the rest of the device.
    • Be careful to not lose the washer when you slide out the fan. You need it when reassembling the device.
Aggiungi Commento
Conclusione
Atlanta Nguyen
Membro da: 25/01/2014
109 Reputazione
1 Guida realizzata
Cal Poly, Team 9-29, Maness Winter 2014 Membro di Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Membri
5 Guide realizzate
WRONG! WRONG!! WRONG!!! On the model BV2500, there's no need to remove any screws on the BLACK fan housing nor on the ORANGE motor housing - you'll make it much harder than it needs to be. Instead, simply push the black fan housing release button on the upper handle near the power switch and the fan housing will tilt off the motor housing. Now, locate the 9/16" plastic cap nut in the middle of the fan and remove it with a socket wrench. You'll need to pry the fan free from the motor shaft. Save the washer under the fan. NOW, you can reverse the order to re-assemble the unit with a new fan. Good luck, and don't trust everything you read on the internet!
pgootos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,398
