Introduzione
The device contains small lights that indicate whether the rice is cooking or being kept warm. In this guide we will the expose the light bulb circuitry to check if it is broken and replace the light bulbs if necessary.
Before disassembling the device, you will need to note and remember which of the lights is not working.
Make sure the device is unplugged before beginning disassembly!
  • Make sure the device is unplugged before beginning disassembly!
  • Lift the lid and bowl from the top of the device.
Aggiungi Commento
Turn the device upside-down, so that the four legs of the device point upwards.
  • Turn the device upside-down, so that the four legs of the device point upwards.
Aggiungi Commento
Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
Aggiungi Commento
Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
Aggiungi Commento
Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
  • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
  • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
Aggiungi Commento
Lift the brass plate off the device and set it aside.
  • Lift the brass plate off the device and set it aside.
Aggiungi Commento
Color coordinating wire groups make it easier to identify the wire groups during reassembly. Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
  • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
  • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
  • Unscrew the screw at the junction near the opposite side of the device from the front panel.
  • Label each of the two wires at this junction with a single color of tape.
Aggiungi Commento
Unscrew the screw at the junction just clockwise from the button panel. Label the three wires of this junction with tape of a second color.
  • Unscrew the screw at the junction just clockwise from the button panel.
  • Label the three wires of this junction with tape of a second color.
Aggiungi Commento
Unscrew the screw from the wire junction just behind the front panel. Label the three wires at this junction with a third color of tape.
  • Unscrew the screw from the wire junction just behind the front panel.
  • Label the three wires at this junction with a third color of tape.
Aggiungi Commento
Using a pair of pliers, bend the brass-colored beam poking through the hotplate's silver colored beam from a "(" shape into a "c" shape so it fits through the hole in the silver-colored beam. Push the brass beam down and pull the silver beam up to disconnect the two beams. Push the brass beam down and pull the silver beam up to disconnect the two beams.
  • Using a pair of pliers, bend the brass-colored beam poking through the hotplate's silver colored beam from a "(" shape into a "c" shape so it fits through the hole in the silver-colored beam.
  • Push the brass beam down and pull the silver beam up to disconnect the two beams.
Aggiungi Commento
Unscrew the four 10mm long 7mm diameter Phillips screws attached to the hotplate. Unscrew the four 10mm long 7mm diameter Phillips screws attached to the hotplate.
  • Unscrew the four 10mm long 7mm diameter Phillips screws attached to the hotplate.
Aggiungi Commento
Carefully lift up the device, either by allowing the hotplate portion to fall out while it is close to the ground, or by catching the hotplate portion as it slides out.
  • Carefully lift up the device, either by allowing the hotplate portion to fall out while it is close to the ground, or by catching the hotplate portion as it slides out.
Aggiungi Commento
Turn the rice cooker so that the front panel is facing down and you have a good view of the inside. Remove the one 8mm long 9mm diameter Phillips screw just above the inside of the front panel.
  • Turn the rice cooker so that the front panel is facing down and you have a good view of the inside.
  • Remove the one 8mm long 9mm diameter Phillips screw just above the inside of the front panel.
Aggiungi Commento
Carefully pull the front panel out along with the silver-colored metal beam.
  • Carefully pull the front panel out along with the silver-colored metal beam.
  • Lay the panel flat, with the silver-colored metal beam facing up.
Aggiungi Commento
Unscrew the 6mm long 5mm diameter Phillips screw from whichever panel(s) correspond(s) to the light that was broken on the other side. Remove the yellow panel(s) by lifting them off or turning the panel upside-down.
  • Unscrew the 6mm long 5mm diameter Phillips screw from whichever panel(s) correspond(s) to the light that was broken on the other side.
  • Remove the yellow panel(s) by lifting them off or turning the panel upside-down.
Aggiungi Commento
For each broken lightbulb, expose the wire leading to the bulb by pulling back the plastic coating on the wire while gently holding onto the bulb. For each broken lightbulb, expose the wire leading to the bulb by pulling back the plastic coating on the wire while gently holding onto the bulb.
  • For each broken lightbulb, expose the wire leading to the bulb by pulling back the plastic coating on the wire while gently holding onto the bulb.
Aggiungi Commento
Using a pair of needlenose pliers or wire strippers, cut the rubber covering on each wire about 5 mm from the edge and pull away the remaining rubber from the light. Using a pair of needlenose pliers or wire strippers, cut the rubber covering on each wire about 5 mm from the edge and pull away the remaining rubber from the light.
  • Using a pair of needlenose pliers or wire strippers, cut the rubber covering on each wire about 5 mm from the edge and pull away the remaining rubber from the light.
Aggiungi Commento
Cut the wires close to the original light so that you will have more wire available for sautering in the next step. Use a pair of wire cutters, diagonal pliers, or sharp scissors, cut the wires leading to the light.
  • Cut the wires close to the original light so that you will have more wire available for sautering in the next step.
  • Use a pair of wire cutters, diagonal pliers, or sharp scissors, cut the wires leading to the light.
Aggiungi Commento
Using a sautering iron, carefully sauter both wire ends of the new light bulb to the device's wires. Make sure that the wires don't cross, as this will stop the light from working.
  • Using a sautering iron, carefully sauter both wire ends of the new light bulb to the device's wires.
  • Make sure that the wires don't cross, as this will stop the light from working.
Aggiungi Commento
Conclusione
Lillian Heng
Membro da: 26/09/2014
601 Reputazione
4 Guide realizzate
Cal Poly, Team 12-1, Forte Fall 2014 Membro di Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 96
Tutti i Tempi: 2,248
