Introduzione
The device contains an internal mechanism used to lock the hotplate into place while cooking. In this guide we will show how to identify whether the mechanism is broken, and how to fix it if it is. Fixing the mechanism involves moving and bending one of the internal parts so it locks into place properly.
Make sure the device is unplugged before beginning disassembly!
  • Make sure the device is unplugged before beginning disassembly!
  • Lift the lid and bowl from the top of the device.
Aggiungi Commento
Turn the device upside-down, so that the four legs of the device point upwards.
  • Turn the device upside-down, so that the four legs of the device point upwards.
Aggiungi Commento
Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
Aggiungi Commento
Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
Aggiungi Commento
Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
  • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
  • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
Aggiungi Commento
Lift the brass plate off the device and set it aside.
  • Lift the brass plate off the device and set it aside.
Aggiungi Commento
Color coordinating wire groups make it easier to identify the wire groups during reassembly. Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
  • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
  • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
  • Unscrew the screw at the junction near the opposite side of the device from the front panel.
  • Label each of the two wires at this junction with a single color of tape.
Aggiungi Commento
Unscrew the screw at the junction just clockwise from the button panel. Label the three wires of this junction with tape of a second color.
  • Unscrew the screw at the junction just clockwise from the button panel.
  • Label the three wires of this junction with tape of a second color.
Aggiungi Commento
Unscrew the screw from the wire junction just behind the front panel. Label the three wires at this junction with a third color of tape.
  • Unscrew the screw from the wire junction just behind the front panel.
  • Label the three wires at this junction with a third color of tape.
Aggiungi Commento
On the inside of the device, there is a silver-colored beam leading to the center with a U-shaped brass beam poking through it.
  • On the inside of the device, there is a silver-colored beam leading to the center with a U-shaped brass beam poking through it.
  • The U-shaped brass beam should be bent outwards so that it cannot fit through the hole in the silver-colored beam.
Aggiungi Commento
If the brass beam is not poking through the silver-colored beam, you will need to position it so that it is. Position the brass beam below the hole in the silver-colored beam and push the silver-colored beam into it, so that the brass beam pokes through.
  • If the brass beam is not poking through the silver-colored beam, you will need to position it so that it is.
  • Position the brass beam below the hole in the silver-colored beam and push the silver-colored beam into it, so that the brass beam pokes through.
Aggiungi Commento
If the brass beam can't fit through the hole in the silver-colored beam, use pliers to bend the brass beam outwards so that it does not fit through the hole in the silver-colored beam.
  • If the brass beam can't fit through the hole in the silver-colored beam, use pliers to bend the brass beam outwards so that it does not fit through the hole in the silver-colored beam.
Aggiungi Commento
Conclusione
Steven Gerick
Membro da: 22/09/2014
364 Reputazione
3 Guide realizzate
Cal Poly, Team 12-1, Forte Fall 2014 Membro di Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,583
