Salta al contenuto principale
Bike Chain Installation
Cosa ti serve
  1. Bike Chain Installation, Bike Chain Installation: passo 1, immagine 1 di 2 Bike Chain Installation, Bike Chain Installation: passo 1, immagine 2 di 2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: passo 2, immagine 1 di 2 Bike Chain Installation: passo 2, immagine 2 di 2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
aaron thielk
Membro da: 10/10/10
1.882 Reputazione
5 Guide realizzate
Cal Poly, Team 5-13, Maness Fall 2010 Membro di Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Membri
17 Guide realizzate
2 Commenti
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 29
Tutti i Tempi: 15,961
