Unplug from all cables
  • Unplug from all cables
Aggiungi Commento
unscrew two Phillips screws on each side of the BCD3000 If the screws sit too tight, you can use the extension for better torque
  • unscrew two Phillips screws on each side of the BCD3000
  • If the screws sit too tight, you can use the extension for better torque
Aggiungi Commento
unscrew another two Phillips screws on each side unscrew another two Phillips screws on each side
  • unscrew another two Phillips screws on each side
Aggiungi Commento
Lift the upper control part. Be careful, there are still some cables connected to the lower section. Disconnect the cables by walking them out of their sockets.
  • Lift the upper control part.
  • Be careful, there are still some cables connected to the lower section.
  • Disconnect the cables by walking them out of their sockets.
Aggiungi Commento
Remove the upper part completely.
  • Remove the upper part completely.
Aggiungi Commento
Disconnect the two cables from the lower section to the connector board.
  • Disconnect the two cables from the lower section to the connector board.
Aggiungi Commento
Slide the lower section to the front. Now you can lift it and take it aside. Now you can lift it and take it aside.
  • Slide the lower section to the front.
  • Now you can lift it and take it aside.
Aggiungi Commento
Disconnect the separate boards. Now you can take the modules out by unscrewing them from the case. Now you can take the modules out by unscrewing them from the case.
  • Disconnect the separate boards.
  • Now you can take the modules out by unscrewing them from the case.
Aggiungi Commento
The jog wheels on the front panel can be taken off by using a spudger and levering them out. The jog wheels on the front panel can be taken off by using a spudger and levering them out.
  • The jog wheels on the front panel can be taken off by using a spudger and levering them out.
Aggiungi Commento
The knobs can easy be removed just by pulling. The knobs can easy be removed just by pulling.
  • The knobs can easy be removed just by pulling.
Aggiungi Commento
Same goes for the knobs on the top section of the front panel. Same goes for the knobs on the top section of the front panel. Same goes for the knobs on the top section of the front panel.
  • Same goes for the knobs on the top section of the front panel.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 31/03/2014
24.124 Reputazione
197 Guide realizzate
iFixit Membro di iFixit
Community
116 Membri
5.778 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 911
