Salta al contenuto principale
Beats Studio First Generation Batteries Replacement
Cosa ti serve
  1. Beats Studio First Generation Batteries Replacement, Identify the Left Speaker Housing: passo 1, immagine 1 di 1
    • The left speaker is the speaker that holds the batteries and does not have the power switch.
  2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: passo 2, immagine 1 di 3 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: passo 2, immagine 2 di 3 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: passo 2, immagine 3 di 3
    • Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
    • Once the cap is loose, simply lift the cap out to reveal the batteries.
  3. Beats Studio First Generation Batteries Replacement, Batteries!: passo 3, immagine 1 di 1
    • Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
Conclusione
Altre 20 persone hanno completato questa guida.
Oscar
Membro da: 04/15/14
1.130 Reputazione
2 Guide realizzate
Cal Poly, Team 9-18, Regan Spring 2014 Membro di Cal Poly, Team 9-18, Regan Spring 2014
CPSU-REGAN-S14S9G18
4 Membri
11 Guide realizzate
27 Commenti
hi man you post is help me a lot thank you..God bless you
EL TIO SAM MARS - Replica
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
Nessa Upzs - Replica
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
John Coops -
Help,I'm trying to twist off battery compartment and it's not budging! Should I try and pry off w/screwdriver! Any ideas?
Kathy - Replica
hello jus curious if u got the cap to come off n how if so? any advice wld b greatly appreciated please n thank u
Randi -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 382
Tutti i Tempi: 145,511
