Introduzione
This guide will show you how to replace the speaker on this phone.
Parti
Nessuna parte richiesta.
Remove the back cover on the phone with the plastic opening tool.
  • Remove the back cover on the phone with the plastic opening tool.
Aggiungi Commento
Remove battery with plastic opening tool.
  • Remove battery with plastic opening tool.
Aggiungi Commento
On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
  • On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
Aggiungi Commento
After removing screws gently pull off the speaker from the back of the phone.
  • After removing screws gently pull off the speaker from the back of the phone.
Aggiungi Commento
Remove the speaker from the backing of the speaker holder.
  • Remove the speaker from the backing of the speaker holder.
Aggiungi Commento
Replace the  old speaker with a new speaker. Put it back in where the old speaker was.
  • Replace the old speaker with a new speaker. Put it back in where the old speaker was.
Aggiungi Commento
Insert the plastic backing of the speaker back in the phone.
  • Insert the plastic backing of the speaker back in the phone.
  • Put the six screws back in the backing of the phone to hold the plastic backing securely.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Maria Juzaino
Membro da: 25/10/2014
493 Reputazione
3 Guide realizzate
Gateway, Team 1-3, Johnson Fall 2014 Membro di Gateway, Team 1-3, Johnson Fall 2014
GCC-JOHNSON-F14S1G3
3 Membri
5 Guide realizzate
Excellent instruction! Great pictures as well! Well done+!
Kelly - Replica
Can you upload a guide on how to replace this device's screen? Pretty much appreciated.
Moe Ojeda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,486
