Introduzione
This guide will show you a step by step guide on how to replace a camera on the BLU Studio 5.0 S II.
Remove the back cover of phone with the plastic opening tool.
  • Remove the back cover of phone with the plastic opening tool.
Aggiungi Commento
Remove the battery with the plastic opening tool.
  • Remove the battery with the plastic opening tool.
Aggiungi Commento
Use the Philips #00 screwdriver to remove the nine screws that the top back part of the phone has.
  • Use the Philips #00 screwdriver to remove the nine screws that the top back part of the phone has.
Aggiungi Commento
Once you take off the screws off the phone remove the plastic backing .
  • Once you take off the screws off the phone remove the plastic backing .
Aggiungi Commento
Remove the ribbon cable carefully on all four sides of the motherboard of the phone. Remove the ribbon cable carefully on all four sides of the motherboard of the phone.
  • Remove the ribbon cable carefully on all four sides of the motherboard of the phone.
Aggiungi Commento
Take off the four interior screws that are on the motherboard of the phone.
  • Take off the four interior screws that are on the motherboard of the phone.
Aggiungi Commento
Remove the ribbon cable next to the camera carefully.
  • Remove the ribbon cable next to the camera carefully.
Aggiungi Commento
Remove the motherboard of the phone and replace camera.
  • Remove the motherboard of the phone and replace camera.
Aggiungi Commento
Conclusione
Maria Juzaino
Membro da: 25/10/2014
493 Reputazione
3 Guide realizzate
Gateway, Team 1-3, Johnson Fall 2014 Membro di Gateway, Team 1-3, Johnson Fall 2014
GCC-JOHNSON-F14S1G3
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,761
