Introduzione
This guide will help teach you how to remove and replace the motorized accelerator near the the tip of the gun by first disassembling the gun, and then showing removal of the accelerator itself. The guide will require a #00 Phillips head screwdriver and requires you to keep track of a few small parts, but is very doable as long as you follow each step!
Parti
Nessuna parte richiesta.
Locate the orange slider on the front side of the gun. Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  • Locate the orange slider on the front side of the gun.
  • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
Aggiungi Commento
Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver. Remove all parts within the chamber to be able to completely detach the nose of the gun. Be careful to keep track of all the components for reassembly.
  • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
  • Remove all parts within the chamber to be able to completely detach the nose of the gun.
  • Be careful to keep track of all the components for reassembly.
Aggiungi Commento
Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver. Look out for the hidden fifth screw behind the thin light green tape near the bushing itself.  Peel the tape using your finger to gain access. Look out for the hidden fifth screw behind the thin light green tape near the bushing itself.  Peel the tape using your finger to gain access.
  • Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
  • Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
Aggiungi Commento
Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
  • Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
  • Remove the bushing by simply pulling it away from the plastic.
Aggiungi Commento
Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver
  • Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver
Aggiungi Commento
Pull back on the accelerator away from the plastic to remove from frame.
  • Pull back on the accelerator away from the plastic to remove from frame.
  • Be careful to not pull too quickly or too hard to avoid damaging the wiring.
Aggiungi Commento
Conclusione
Reed Garmsen
Membro da: 07/10/2014
339 Reputazione
2 Guide realizzate
Cal Poly, Team 6-22, Maness Fall 2014 Membro di Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 433
