Salta al contenuto principale
Audiovox CR8030iE5 Top-Casing Replacement
Cosa ti serve
  1. Audiovox CR8030iE5 Top-Casing Replacement, Top-Casing: passo 1, immagine 1 di 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Top-Casing Replacement: passo 2, immagine 1 di 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Top-Casing Replacement: passo 3, immagine 1 di 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Top-Casing Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Top-Casing Replacement: passo 5, immagine 1 di 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
Conclusione
Cal Poly, Team 10-39, Amido Spring 2013 Membro di Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 332
