Salta al contenuto principale
Audiovox CR8030iE5 AUX Port Replacement
Cosa ti serve
  1. Audiovox CR8030iE5 AUX Port Replacement, Top-Casing: passo 1, immagine 1 di 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 AUX Port Replacement: passo 2, immagine 1 di 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 AUX Port Replacement: passo 3, immagine 1 di 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 AUX Port Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 AUX Port Replacement: passo 5, immagine 1 di 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 AUX Port Replacement, AUX Port: passo 6, immagine 1 di 1
    • To remove the faulty AUX port wires, de-solder the two wires on the white rectangular region of the board.
    • If you don't know how to solder, check out Come saldare e dissaldare componenti elettrici.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 AUX Port Replacement: passo 7, immagine 1 di 1
    • Carefully insert the new AUX port wires into their designated holes and solder them into place.
    • If you don't know how to solder, use the guide, Come saldare e dissaldare componenti elettrici.
Conclusione
Nab Sengupta
Membro da: 04/18/13
55 Reputazione
4 Guide realizzate
Cal Poly, Team 10-39, Amido Spring 2013 Membro di Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 839
