Parti
Nessuna parte richiesta.
Locate the back side of the phone.
  • Locate the back side of the phone.
  • The battery is the large main compartment (red box).
Aggiungi Commento
Use your finger to slide the latch (circled) upwards.
  • Use your finger to slide the latch (circled) upwards.
  • While holding the latch up, pull the battery off the phone.
Aggiungi Commento
The back of the phone will look like this when the battery is correctly removed.
  • The back of the phone will look like this when the battery is correctly removed.
Aggiungi Commento
Peel the rubber indicated toward the top of the phone
  • Peel the rubber indicated toward the top of the phone
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the screw that sits underneath the rubber covering.
  • Remove the screw that sits underneath the rubber covering.
Aggiungi Commento
Remove the five (5) total screws using a Philips head screwdriver.
  • Remove the five (5) total screws using a Philips head screwdriver.
Aggiungi Commento
Use spudger and insert it towards the bottom of the phone as pictured.
  • Use spudger and insert it towards the bottom of the phone as pictured.
  • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
  • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
Aggiungi Commento
The back case should now be completely removed and the motherboard will be visible.
  • The back case should now be completely removed and the motherboard will be visible.
Aggiungi Commento
Disconnect the gold connection patch Use a spudger or finger to disconnect the piece. Use a spudger or finger to disconnect the piece.
  • Disconnect the gold connection patch
  • Use a spudger or finger to disconnect the piece.
Aggiungi Commento
Using a spudger, lift the motherboard out of the phone case as pictured.
  • Using a spudger, lift the motherboard out of the phone case as pictured.
Aggiungi Commento
The motherboard should now be completely removed from the phone.
  • The motherboard should now be completely removed from the phone.
Aggiungi Commento
Conclusione
Sean Green
Membro da: 04/10/2010
11 Reputazione
4 Guide realizzate
Cal Poly, Team 3-24, Regan Fall 2010 Membro di Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,059
