Introduzione
The LCD screen is the main display of the Audiovox CDM-8910.
Parti
Nessuna parte richiesta.
With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
Aggiungi Commento
Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
Aggiungi Commento
Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
Aggiungi Commento
Use a spudger to lift away and remove the metallic frame (in blue).
  • Use a spudger to lift away and remove the metallic frame (in blue).
  • Use the spudger to lift away the two electrical contacts (in red).
  • Use the spudger to lift away the speaker (in yellow).
Aggiungi Commento
This is what the rear of the LCD screen should look like before proceeding.  Note all necessary connections are undone.
  • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
Aggiungi Commento
Use a spudger to lift away the LCD screen.
  • Use a spudger to lift away the LCD screen.
Aggiungi Commento
LCD screen successfully removed!
  • LCD screen successfully removed!
Aggiungi Commento
Conclusione
Kevin Jafarey
Membro da: 04/10/2010
11 Reputazione
4 Guide realizzate
Cal Poly, Team 3-24, Regan Fall 2010 Membro di Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,756
