Salta al contenuto principale
Audio Technica ATH-AD500 Right Headphone Cable Replacement
Cosa ti serve
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: passo 1, immagine 1 di 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 2, immagine 1 di 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 3, immagine 1 di 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: passo 4, immagine 1 di 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: passo 4, immagine 2 di 2
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference Come saldare e dissaldare componenti elettrici.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 5, immagine 1 di 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 5, immagine 2 di 2
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference Come saldare e dissaldare componenti elettrici.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 17-19, Forte Winter 2013 Membro di Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Membri
17 Guide realizzate
3 Commenti
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - Replica
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - Replica
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,513
