Introduzione
The controller's joystick is connected to a sensor via sliding plates, which then move two knobs(one per axis), which are placed inside two pots whose movement the sensors detects. The knobs can occasionally get dislodged out of the pots, causing a "stuck" and undetected joystick.
Cosa ti serve
Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
Find the knobs (closest to the joystick and circled in red).
Locate the pots (closest to the circuitry and circled in orange). Keep track of these.
Align the joystick's metal bar into its cup.
Use a spudger to remove the top frame.
Take off the plate.
Remove the rubber buttons.
Realign the top and bottom of the controller.
Pull the circuit strip through the new space.
Return the start buttons to the top of the controller
Snap the frame back into place
Screw in the three screws on the back.
Altre 4 persone hanno completato questa guida.
