Introduzione
The touch pad controls cursor movement and is one of the most used parts of the laptop. It is exposed to frequent wear and tear and may need replacement.
Parti
Nessuna parte richiesta.
Power off and unplug your laptop before you begin.
  • Power off and unplug your laptop before you begin.
  • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
screw assignments are definitely wrong. I swapped the red and the green, as per comment above, and kept the blue as-is.
jasonbuechler - Replica
jason is right
starwilson - Replica
correct, swap the green and red
Josh - Replica
Jason is correct
Clem Lanoe - Replica
Thanks everyone. It does seem like someone got their screws mixed up when they wrote this guide. I’ve made some changes as you all suggested, so the screw placements should be more accurate now. If anyone with this laptop could verify the screw measurements with a digital caliper, that’d also be very helpful.
Jeff Suovanen - Replica
Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
Aggiungi Commento
Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
Aggiungi Commento
Invert the laptop in order to gain access to the ribbons. Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon. Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  • Invert the laptop in order to gain access to the ribbons.
  • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
Don't remove the ribbons, just move the keyboard slightly forward to remove the old battery and insert the new one (just make sure they are all connected when you put it back)
Flyer292 - Replica
Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
Is painting your nails crucial for step 5?
wiedzmin - Replica
Yes and you have to put lotion on
joemidjette - Replica
Now, that is a stupid question! Of course! As I am working on 551M, I naturally have to have nails painted orange, with blue accents!
gregtokarski -
that boy ain't right
Rich Spillman - Replica
Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
Aggiungi Commento
Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
Aggiungi Commento
Once it is free, remove the hard drive from its internal cavity.
  • Once it is free, remove the hard drive from its internal cavity.
Aggiungi Commento
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
this spacer may be a cd rom drive or potentially a second storage device like an ssd or hard drive. Either way the process is the same, remove the single screw, and slide to the right.
Josh - Replica
Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
  • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
Aggiungi Commento
Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
  • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
Aggiungi Commento
Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
  • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
Aggiungi Commento
Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
  • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
mine only had the black cable and the small wifi card was slightly different. the card itself has two available connections and is labeled as to where the black cable (main) and white cable if it were present (aux) cables connect.
Josh - Replica
Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
  • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
Aggiungi Commento
With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
  • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
there is one more screw that must be removed at the bottom right corner of the motherboard, just out of view.
Josh - Replica
Now, locate the two wires connected to the motherboard. Now, locate the two wires connected to the motherboard.
  • Now, locate the two wires connected to the motherboard.
Aggiungi Commento
Remove the wires by easily pulling them parallel to the motherboard's surface. The wires are very fragile. Be sure to pull carefully so that they do not break!
  • Remove the wires by easily pulling them parallel to the motherboard's surface.
  • The wires are very fragile. Be sure to pull carefully so that they do not break!
Aggiungi Commento
Remove the LCD display connection by gently pulling on the attached wire. Gently lift any tape that may be holding the connection.
  • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
If the tape is removed when disconnecting, be SUPER sure that the connector is the right way before reconnecting. I managed to brake this connector by putting it in the wrong way! Both sides look very similar.
Ben Garrod - Replica
Remove the motherboard from the case by gently lifting it upward.
  • Remove the motherboard from the case by gently lifting it upward.
Aggiungi Commento
Flip over the keyboard plate cover so the keys are facing down to locate the back of the touch pad.
  • Flip over the keyboard plate cover so the keys are facing down to locate the back of the touch pad.
Aggiungi Commento
Pull up the aluminum tape off of the keyboard cover until it is only attached to the touch pad.
  • Pull up the aluminum tape off of the keyboard cover until it is only attached to the touch pad.
  • Do not fully remove the aluminum tape!
Aggiungi Commento
Locate and unscrew the three 3.2 mm Phillips #0 screws at the top edge of the touch pad using the Phillips #0 screwdriver.
  • Locate and unscrew the three 3.2 mm Phillips #0 screws at the top edge of the touch pad using the Phillips #0 screwdriver.
Aggiungi Commento
Lift the top edge and gently slide the bottom edge out from underneath the keyboard plate cover.
  • Lift the top edge and gently slide the bottom edge out from underneath the keyboard plate cover.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Taylor Downey
Membro da: 13/04/2014
825 Reputazione
2 Guide realizzate
Cal Poly, Team 7-22, Regan Spring 2014 Membro di Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Membri
15 Guide realizzate
why on earth would you do all that do change the touchpad?
it would be step 1,2,3,4,5,21,22,23
Eric Serra - Replica
I agree with Mr Serra - you wouldn't need to touch the Motherboard/hard drive.
Jane Armstrong - Replica
crazy! lol there is no need for you to remove the motherboard just to replace the touch pad :D
randy - Replica
Where can I buy replacement touch pad?
Nin Kasi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 232
Tutti i Tempi: 8,815
