Parti
Nessuna parte richiesta.
Remove the following six screws:
  • Remove the following six screws:
    • Six 4 mm Phillips #0 using a phillips scredriver
  • Remove the following one screw:
    • One 14 mm Phillips #0 using a phillips screwdriver
  • The 14mm screw goes in the center.
There are also two other screws under the rubber feet above the battery.
digg1024 - Replica
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Clément Marshall - Replica
Take gold cap that connects to a black wire off using the metal spudger.
  • Take gold cap that connects to a black wire off using the metal spudger.
Aggiungi Commento
Remove the following two screws:
  • Remove the following two screws:
    • Two 4 mm screws using Phillips #0 screwdriver.
Aggiungi Commento
Slide the component up and out.
  • Slide the component up and out.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Vanessa Garcia
Membro da: 22/01/2015
1.508 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 61
Tutti i Tempi: 2,293
