Introduzione
Use this guide to replace the trackpad on your Asus X200MA.
Remove the following six screws:
  • Remove the following six screws:
    • Six 4 mm Phillips #0 using a phillips scredriver
  • Remove the following one screw:
    • One 14 mm Phillips #0 using a phillips screwdriver
  • The 14mm screw goes in the center.
There are also two other screws under the rubber feet above the battery.
digg1024 - Replica
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Clément Marshall - Replica
Use the spudger to lift up and remove the black plastic covering. Use the spudger to lift up and remove the black plastic covering.
  • Use the spudger to lift up and remove the black plastic covering.
Aggiungi Commento
Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
Aggiungi Commento
Remove wider blue strip with tweezers.
  • Remove wider blue strip with tweezers.
Aggiungi Commento
Remove the following eight screws:
  • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
Aggiungi Commento
Remove the following two screws after lifting metal plate off:
  • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
Aggiungi Commento
Use metal spudger to get in between mouse pad and keyboard and lift off. Use metal spudger to get in between mouse pad and keyboard and lift off.
  • Use metal spudger to get in between mouse pad and keyboard and lift off.
Aggiungi Commento
Conclusione
Vanessa Garcia
Membro da: 22/01/2015
1.508 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,033
