Parti
Nessuna parte richiesta.
Remove the following six screws:
  • Remove the following six screws:
    • Six 4 mm Phillips #0 using a phillips scredriver
  • Remove the following one screw:
    • One 14 mm Phillips #0 using a phillips screwdriver
  • The 14mm screw goes in the center.
There are also two other screws under the rubber feet above the battery.
digg1024 - Replica
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Clément Marshall - Replica
Conclusione
Altre 7 persone hanno completato questa guida.
Vanessa Garcia
Membro da: 22/01/2015
1.508 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,866
