Salta al contenuto principale
Asus X200MA Hard Drive Replacement
Cosa ti serve
  1. Asus X200MA Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Remove the black foam and adhesive located on top of the hard drive.
  4. Asus X200MA Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  5. Asus X200MA Hard Drive Replacement: passo 5, immagine 1 di 1
    • Slide out the hard drive
Conclusione
Altre 3 persone hanno completato questa guida.
Vanessa Garcia
Membro da: 01/22/15
1.763 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
8 Guide realizzate
2 Commenti
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Replica
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 9,281
