Parti
Nessuna parte richiesta.
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles. Unscrew the 2 4 mm Phillips head screws by the battery. Unscrew the 2 4 mm Phillips head screws by the battery.
  • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
  • Unscrew the 2 4 mm Phillips head screws by the battery.
Aggiungi Commento
Remove the panel above the keyboard with a plastic spudger.
  • Remove the panel above the keyboard with a plastic spudger.
Aggiungi Commento
Once the panel is removed, use the spudger to pry out the keyboard.
  • Once the panel is removed, use the spudger to pry out the keyboard.
  • Do not fully remove, for the keyboard is still attached to the ribbon cable.
Aggiungi Commento
Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop. Be sure to detach from the root rather than from near the middle. It should slide out with ease.
  • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
  • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
  • Now you can fully remove the keyboard from the laptop.
Aggiungi Commento
Place your fingers or a spudger between the front panel and the rest of the laptop.
  • Place your fingers or a spudger between the front panel and the rest of the laptop.
  • Pull upwards gently to detach the side you are grabbing.
  • Repeat on the other side until the panel easily peels off the laptop.
Aggiungi Commento
The touchpad should be loosely attached to the rest of the laptop by a ribbon cable. The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
Aggiungi Commento
Gently pull the ribbon cable out of its socket attached to the touchpad.
  • Gently pull the ribbon cable out of its socket attached to the touchpad.
  • You are now able to remove the touchpad.
Aggiungi Commento
Conclusione
Nolan Schock
Membro da: 14/04/2014
501 Reputazione
5 Guide realizzate
Cal Poly, Team 13-29, Maness Spring 2014 Membro di Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 163
