Introduzione
Replace a broken hard drive or upgrade your hard drive to increase your storage space.
Parti
Nessuna parte richiesta.
Before disassembly, make sure the laptop is powered off and the battery is disconnected.
  • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
  • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
Aggiungi Commento
Grab the panel and lift upwards while pulling towards yourself.
  • Grab the panel and lift upwards while pulling towards yourself.
Aggiungi Commento
Remove the 3 4 mm Phillips upper screws holding the hard drive down.
  • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
Aggiungi Commento
Pull the hard drive towards yourself to disconnect it from the laptop.
  • Pull the hard drive towards yourself to disconnect it from the laptop.
Aggiungi Commento
Lift the hard drive upwards to remove it from the laptop.
  • Lift the hard drive upwards to remove it from the laptop.
Aggiungi Commento
Conclusione
Nolan Schock
Membro da: 14/04/2014
501 Reputazione
5 Guide realizzate
Cal Poly, Team 13-29, Maness Spring 2014 Membro di Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 171
