Salta al contenuto principale
Asus VivoBook Q200E-BSI3T08 Trackpad Replacement
Cosa ti serve
  1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 2, immagine 1 di 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 3, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 5, immagine 1 di 3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 5, immagine 2 di 3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 5, immagine 3 di 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 6, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 6, immagine 2 di 2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Trackpad: passo 7, immagine 1 di 1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  8. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 8, immagine 1 di 1
    • Identify the ten 2.94mm screws on the metal bracket.
  9. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 9, immagine 1 di 1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  10. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 10, immagine 1 di 1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  11. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 11, immagine 1 di 1
    • Lift the metal bracket away from the laptop.
  12. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 12, immagine 1 di 1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  13. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: passo 13, immagine 1 di 1
    • Lift the trackpad up from the laptop and slide it out of the housing.
Conclusione
IUPUI, Team S4-G4, Wilson Summer 2017 Membro di IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 566
