Salta al contenuto principale
Asus VivoBook Q200E-BSI3T08 Battery Replacement
Cosa ti serve
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 3, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 5, immagine 1 di 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 5, immagine 2 di 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 5, immagine 3 di 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 6, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 6, immagine 2 di 2
    • Now just lift the battery out of place.
Conclusione
Altre 14 persone hanno completato questa guida.
Maxim
Membro da: 01/21/15
462 Reputazione
1 Guida realizzata
UWT Liner: Group 6 Membro di UWT Liner: Group 6
Community
3 Membri
1 Guida realizzata
2 Commenti
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Replica
Great guide. Thanks!
weston.fisher - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 7,346
