Flip the computer over so that it is upside down. Slide both latches away from each other (towards the outside).
  • Flip the computer over so that it is upside down.
  • Slide both latches away from each other (towards the outside).
  • Push the battery out with your fingers.
  • The actual battery is not shown in the photograph.
Aggiungi Commento
On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
  • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
  • Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
Aggiungi Commento
Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
  • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
Aggiungi Commento
After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
  • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
Aggiungi Commento
After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
  • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
  • Carefully insert the new ram in at the same angle that you removed it at.
  • The other side of the RAM slot is a place for more RAM if you want to put more in. The spaces are highlighted in blue.
Aggiungi Commento
Conclusione
Connor
Membro da: 24/06/2010
36 Reputazione
1 Guida realizzata
Cal Poly, Team 2-9, Johann Summer 2010 Membro di Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,118
