Salta al contenuto principale
Asus V6800V Fan Replacement
Cosa ti serve
  1. Asus V6800V Fan Replacement, Battery: passo 1, immagine 1 di 2 Asus V6800V Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: passo 2, immagine 1 di 2 Asus V6800V Fan Replacement, Fan: passo 2, immagine 2 di 2
    • Use the Phillips #0 to remove the six screws on the back of the device.
    • Gently open the cover using the tab located by the highlighted box.
  3. Asus V6800V Fan Replacement: passo 3, immagine 1 di 2 Asus V6800V Fan Replacement: passo 3, immagine 2 di 2
    • Unplug the wires by pulling straight up on the white connector and away from the computer.
    • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: passo 4, immagine 1 di 2 Asus V6800V Fan Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #0 to remove the three screws holding the fan in place.
  5. Asus V6800V Fan Replacement: passo 5, immagine 1 di 2 Asus V6800V Fan Replacement: passo 5, immagine 2 di 2
    • Remove the fan from the device.
    • The fan should remove easily.
  6. Asus V6800V Fan Replacement: passo 6, immagine 1 di 2 Asus V6800V Fan Replacement: passo 6, immagine 2 di 2
    • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
Conclusione
Jong Park
Membro da: 06/24/10
114 Reputazione
5 Guide realizzate
Cal Poly, Team 2-9, Johann Summer 2010 Membro di Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,950
