Salta al contenuto principale
Asus Transformer Pad Infinity Glass Replacement
Cosa ti serve
  1. Asus Transformer Pad Infinity Glass Replacement, Glass: passo 1, immagine 1 di 3 Asus Transformer Pad Infinity Glass Replacement, Glass: passo 1, immagine 2 di 3 Asus Transformer Pad Infinity Glass Replacement, Glass: passo 1, immagine 3 di 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity Glass Replacement: passo 2, immagine 1 di 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity Glass Replacement: passo 3, immagine 1 di 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity Glass Replacement: passo 4, immagine 1 di 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity Glass Replacement: passo 5, immagine 1 di 1
    • Once removed, replace the glass screen back onto the LCD display.
    • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
Conclusione
Allison Poh
Membro da: 10/20/15
549 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 816
