Salta al contenuto principale
Asus ROG G751JL-DS71 Battery Replacement
Cosa ti serve
  1. Asus ROG G751JL-DS71 Battery Replacement, CD-ROM Player: passo 1, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, CD-ROM Player: passo 1, immagine 2 di 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Battery Replacement: passo 2, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 2, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 2, immagine 3 di 3
    • Use the nylon spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Battery Replacement: passo 3, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 3, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Battery Replacement: passo 4, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 4, immagine 2 di 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Battery Replacement, Top Rear Panel: passo 5, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, Top Rear Panel: passo 5, immagine 2 di 2
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  6. Asus ROG G751JL-DS71 Battery Replacement: passo 6, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 6, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  7. Asus ROG G751JL-DS71 Battery Replacement: passo 7, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 7, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 7, immagine 3 di 3
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  8. Asus ROG G751JL-DS71 Battery Replacement, Keyboard: passo 8, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement, Keyboard: passo 8, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement, Keyboard: passo 8, immagine 3 di 3
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
  9. Asus ROG G751JL-DS71 Battery Replacement: passo 9, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 9, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  10. Asus ROG G751JL-DS71 Battery Replacement: passo 10, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 10, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 10, immagine 3 di 3
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  11. Asus ROG G751JL-DS71 Battery Replacement: passo 11, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 11, immagine 2 di 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  12. Asus ROG G751JL-DS71 Battery Replacement, Monitor: passo 12, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, Monitor: passo 12, immagine 2 di 2
    • Use a pair of tweezers to carefully disconnect the pin connector.
  13. Asus ROG G751JL-DS71 Battery Replacement: passo 13, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 13, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 13, immagine 3 di 3
    • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
    • The monitor is now free to be completely lifted off the laptop.
  14. Asus ROG G751JL-DS71 Battery Replacement, Battery: passo 14, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, Battery: passo 14, immagine 2 di 2
    • Disconnect the pin connector that attaches the battery to the motherboard.
    • Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
  15. Asus ROG G751JL-DS71 Battery Replacement: passo 15, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 15, immagine 2 di 2
    • The battery can now be lifted away from the laptop.
Conclusione
Altre 7 persone hanno completato questa guida.
Aurora Rios
Membro da: 01/22/18
917 Reputazione
4 Guide realizzate
Cal Poly, Team S16-G1, Banghart Winter 2018 Membro di Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Membri
22 Guide realizzate
3 Commenti
Can yo please share the review of this battery? Should I go for original battery or ifixit battery?
Chintan Goyal - Replica
Thank you so much for this Aurora it really helped me work on my ROG, hope my extra notes on Section 11 & 12 help others! Blessings!
Off Duty Pastor - Replica
I have a G751JT-CH71 & I'm not sure if the models are slightly different but I cannot remove the battery by simply lifting it out of the compartment. The battery has 4 lock-in tabs towards the back of the laptop AND 2 additional tabs that are beneath the board. I'm going to carefully pry the battery out, but I'm unsure if there's a recommended method to prying the battery out…
Daniel Sierra - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 65
Tutti i Tempi: 5,592
