Hold down the power button
  • Hold down the power button
Aggiungi Commento
Use plastic opening tool to pry off the back cover of the phone. Use plastic opening tool to pry off the back cover of the phone. Use plastic opening tool to pry off the back cover of the phone.
  • Use plastic opening tool to pry off the back cover of the phone.
Aggiungi Commento
Remove the warning sticker that covers the battery plug and connecting cord. Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out. The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
  • Remove the warning sticker that covers the battery plug and connecting cord.
  • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
  • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
  • Disconnect battery connecting cord using tweezers.
Aggiungi Commento
Use T5 Torx screwdriver to remove 14 screws from internal back plate. Use of magnetic pad will help with keeping track of screws.
  • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
  • Use of magnetic pad will help with keeping track of screws.
  • Once screws are out, remove the plate.
Aggiungi Commento
Use tweezers to remove motor from housing, pulling the plug downward away from the phone. Use tweezers to unplug the device from the circuit board.
  • Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
  • Use tweezers to unplug the device from the circuit board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Zach Standridge
Membro da: 25/09/2014
308 Reputazione
2 Guide realizzate
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro di USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,132
