Salta al contenuto principale
Asus Padfone 2 Camera Replacement
Cosa ti serve
  1. Asus Padfone 2 Camera  Replacement, Power Down Device: passo 1, immagine 1 di 1
    • Hold down the power button.
  2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: passo 2, immagine 1 di 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: passo 2, immagine 2 di 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: passo 2, immagine 3 di 3
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Camera  Replacement, Battery Removal: passo 3, immagine 1 di 3 Asus Padfone 2 Camera  Replacement, Battery Removal: passo 3, immagine 2 di 3 Asus Padfone 2 Camera  Replacement, Battery Removal: passo 3, immagine 3 di 3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: passo 4, immagine 1 di 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: passo 4, immagine 2 di 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: passo 4, immagine 3 di 3
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: passo 5, immagine 1 di 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: passo 5, immagine 2 di 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: passo 5, immagine 3 di 3
    • Disconnect four plugs to the motherboard using tweezers.
    • Lift up green motherboard.
  6. Asus Padfone 2 Camera  Replacement, Removing Camera: passo 6, immagine 1 di 2 Asus Padfone 2 Camera  Replacement, Removing Camera: passo 6, immagine 2 di 2
    • Remove camera from back of the motherboard with tweezers.
Conclusione
Altre 3 persone hanno completato questa guida.
Erica
Membro da: 09/25/14
467 Reputazione
2 Guide realizzate
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro di USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,973
