Slide the battery's locking tabs from the locked position to unlocked positions. The right tab is unlocked when a red dot is showing. The left tab will have to be held in the unlocked position in order to release the battery.
  • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
Aggiungi Commento
Slide the battery out while holding the left locking tab in the unlocked position.
  • Slide the battery out while holding the left locking tab in the unlocked position.
Aggiungi Commento
Identify the RAM and hard drive compartment on the back of the laptop and locate the two screws holding it in place.
  • Identify the RAM and hard drive compartment on the back of the laptop and locate the two screws holding it in place.
  • There may be a sticker covering one of the screws. If not, proceed to step 5.
Aggiungi Commento
Remove the sticker with your hand or a tweezer.
  • Remove the sticker with your hand or a tweezer.
Aggiungi Commento
Remove the two 4.76 mm Phillips #0 screws.
  • Remove the two 4.76 mm Phillips #0 screws.
Aggiungi Commento
Carefully open up the cover from the bottom with a plastic opening tool.
  • Carefully open up the cover from the bottom with a plastic opening tool.
Aggiungi Commento
Remove the back cover.
  • Remove the back cover.
Aggiungi Commento
Identify the RAM (the bottom chip)
  • Identify the RAM (the bottom chip)
    • It is held in place by two pins
Aggiungi Commento
Use a spudger to push the end of the small metal clip on the right towards the right.
  • Use a spudger to push the end of the small metal clip on the right towards the right.
  • Now push the end of the small metal clip on the left towards the left.
  • The RAM should pop up.
Aggiungi Commento
Remove the RAM by pulling it upwards.
  • Remove the RAM by pulling it upwards.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Brian Carreon
Membro da: 25/01/2012
171 Reputazione
4 Guide realizzate
Cal Poly, Team 3-27, Amido Winter 2012 Membro di Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 39
Tutti i Tempi: 6,744
