Turn the power off and turn the netbook upside down. Slide both battery catches together to release the battery.
  • Turn the power off and turn the netbook upside down.
  • Slide both battery catches together to release the battery.
  • Slide the battery out.
While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
Tolidano - Replica
Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
Andrea Borgia - Replica
Locate the memory compartment. Using a Plastic Opening Tools, remove the screw rubber cover. Remove the screw.
  • Locate the memory compartment.
Aggiungi Commento
Use a Plastic Opening Tools near the screw hole to release the cover.
Aggiungi Commento
  • Using a Spudger, push both right and left metal clip to release one of the RAM module.
  • Slide out the RAM module.
  • Do the same with the second RAM module if necessary.
Aggiungi Commento
Conclusione
Gaetan
Membro da: 26/12/2012
9.276 Reputazione
30 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,343
