Introduzione
You will be the remove of the battery and continue to cautiously take the graphics card off of the laptop. This installation would be necessary if a user has a fried, defected, or inoperative in general.
Using the Plastic Opening Tool, carefully pry the top panel from the base.
  • Using the Plastic Opening Tool, carefully pry the top panel from the base.
Aggiungi Commento
Lift the side of the keyboard gently and disconnect the attached ribbon located underneath the keyboard. Place your index finger in the hole on the right side of the keyboard tray and lift the tray gently. Place your index finger in the hole on the right side of the keyboard tray and lift the tray gently.
  • Lift the side of the keyboard gently and disconnect the attached ribbon located underneath the keyboard.
  • Place your index finger in the hole on the right side of the keyboard tray and lift the tray gently.
Aggiungi Commento
Use your fingers to lift the battery and gently disconnect the wires from the base. Use your fingers to lift the battery and gently disconnect the wires from the base.
  • Use your fingers to lift the battery and gently disconnect the wires from the base.
Aggiungi Commento
Remove the 2mm screws from the graphics card (circled in red).
  • Remove the 2mm screws from the graphics card (circled in red).
Aggiungi Commento
Flip over the graphics card. Pull the black plastic locking mechanism towards the golden ribbon to unlock. Pull out the ribbon.
  • Flip over the graphics card.
  • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
  • Pull out the ribbon.
Aggiungi Commento
Replace graphics card!
  • Replace graphics card!
Aggiungi Commento
Conclusione
Alex Powers
Membro da: 17/04/2013
101 Reputazione
2 Guide realizzate
Cal Poly, Team 21-52, Johann Spring 2013 Membro di Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membri
6 Guide realizzate
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,698
