Introduzione
This task will normally be performed if the fan is faulty, broken, or if the user is trying to disassemble the entire device. You will start with removing the keyboard and continue to carefully remove parts within the laptop to finally disconnect fan for replacement.
Using the Plastic Opening Tool, carefully pry the top panel from the base.
  • Using the Plastic Opening Tool, carefully pry the top panel from the base.
Aggiungi Commento
Lift the side of the keyboard gently and disconnect the attached ribbon located underneath the keyboard. Place your index finger in the hole on the right side of the keyboard tray and lift the tray gently. Place your index finger in the hole on the right side of the keyboard tray and lift the tray gently.
  • Lift the side of the keyboard gently and disconnect the attached ribbon located underneath the keyboard.
  • Place your index finger in the hole on the right side of the keyboard tray and lift the tray gently.
Aggiungi Commento
Use your fingers to lift the battery and gently disconnect the wires from the base. Use your fingers to lift the battery and gently disconnect the wires from the base.
  • Use your fingers to lift the battery and gently disconnect the wires from the base.
Aggiungi Commento
Remove the 2mm screws on the copper heat sink on the left side of the device. Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink. Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink.
  • Remove the 2mm screws on the copper heat sink on the left side of the device.
  • Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink.
Aggiungi Commento
Remove the small white connector attached to the fan (make sure to pull from the white connector and not with the wires as this can cause damage to the component) Replace with new fan!
  • Remove the small white connector attached to the fan (make sure to pull from the white connector and not with the wires as this can cause damage to the component)
  • Replace with new fan!
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Michael Dooley
Membro da: 18/04/2013
132 Reputazione
3 Guide realizzate
Cal Poly, Team 21-52, Johann Spring 2013 Membro di Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,356
