Introduzione
The RAM is located under the plastic casing of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in.
Parti
Nessuna parte richiesta.
Start by having the laptop upside down on a hard flat surface. Find and unscrew the 6.65 mm Phillips #1 screw.
  • Start by having the laptop upside down on a hard flat surface.
  • Find and unscrew the 6.65 mm Phillips #1 screw.
  • The screw will not detach from the RAM cover.
Aggiungi Commento
Carefully remove the cover by lifting it with your fingers. Make sure that you do not pull the cover to quickly or too hard as this could damage the plastic pins that hold the cover on.
  • Carefully remove the cover by lifting it with your fingers.
  • Make sure that you do not pull the cover to quickly or too hard as this could damage the plastic pins that hold the cover on.
Aggiungi Commento
Identify the pins on both sides of the RAM. Using both hands, pull the pins apart from each other to release the RAM.
  • Identify the pins on both sides of the RAM.
  • Using both hands, pull the pins apart from each other to release the RAM.
  • The RAM will "pop" up on its own after the pins are pressed.
Aggiungi Commento
Grab the RAM stick with two fingers and gently pull it out of its slot.
  • Grab the RAM stick with two fingers and gently pull it out of its slot.
Aggiungi Commento
Conclusione
Aaron Arenas
Membro da: 20/04/2014
667 Reputazione
5 Guide realizzate
Cal Poly, Team 13-32, Maness Spring 2014 Membro di Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Membri
5 Guide realizzate
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
Dan Fowler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 530
