Introduzione
Use this guide to replace the screen of the Replace the screen on your Asus Eee PC 1005HA laptop.
Lay the laptop upside down.
  • Lay the laptop upside down.
  • Locate the two battery lock tabs.
Aggiungi Commento
Slide the tabs outward to unlock the battery. The left tab will remain unlocked, while the right tab must be held. Holding the right tab open, slide the battery out of the laptop.
  • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
  • Holding the right tab open, slide the battery out of the laptop.
Aggiungi Commento
Using tweezers, remove the six screw covers on the screen bezel. Remove the six 4.6 mm screws from the bezel. Remove the six 4.6 mm screws from the bezel.
  • Using tweezers, remove the six screw covers on the screen bezel.
  • Remove the six 4.6 mm screws from the bezel.
Aggiungi Commento
Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
  • Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
  • Carefully remove the bezel from the display.
Aggiungi Commento
Remove the four 3.6 mm screws securing the screen. Slowly lift the screen up from the rest of the laptop. The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
  • Remove the four 3.6 mm screws securing the screen.
  • Slowly lift the screen up from the rest of the laptop.
  • The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
Aggiungi Commento
Remove the plastic tape securing the display cables to the back of the screen. Slide the display cable connector out its socket on the back of the screen.
  • Remove the plastic tape securing the display cables to the back of the screen.
  • Slide the display cable connector out its socket on the back of the screen.
Aggiungi Commento
Remove the four 3.1 mm housing screws on the sides of the display housing frame Remove the housing frame.
  • Remove the four 3.1 mm housing screws on the sides of the display housing frame
  • Remove the housing frame.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Mitchell Cesare
Membro da: 31/01/2012
705 Reputazione
4 Guide realizzate
Cal Poly, Team 11-22, Maness Winter 2012 Membro di Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 61
Tutti i Tempi: 18,107
