Remove the (6.65 mm) screw next to the RAM. Remove the (6.65 mm) screw next to the RAM.
  • Remove the (6.65 mm) screw next to the RAM.
Aggiungi Commento
Open back cover Remove each of the 6 (5.5 mm) screws on the inside covering. Identify and disconnect touch pad ribbon cable which can be seen through a window at the bottom edge of the metal part of the top casing ( in these photos the connector shows blue)
  • Open back cover
  • Remove each of the 6 (5.5 mm) screws on the inside covering.
  • Identify and disconnect touch pad ribbon cable which can be seen through a window at the bottom edge of the metal part of the top casing ( in these photos the connector shows blue)
Aggiungi Commento
Remove (6.65 mm) screw next to RAM
  • Remove (6.65 mm) screw next to RAM
Aggiungi Commento
Turn computer right side up, and open it. Remove 6 (5.5 mm) screws from inside covering.
  • Turn computer right side up, and open it.
  • Remove 6 (5.5 mm) screws from inside covering.
  • Disconnect the touch pad ribbon cable.
Aggiungi Commento
Top plastic is fragile. Handle gently. Two miniature LEDs will be exposed in the top edge of the bottom casing. Handle with caution to avoid damage.
  • Top plastic is fragile. Handle gently.
  • Two miniature LEDs will be exposed in the top edge of the bottom casing. Handle with caution to avoid damage.
  • Detach each of the 5 plastic clips. Run a plastic opening tool along the underside of the top half. You will hear the 'clicks' of the clips coming undone.
  • Remove plastic covering
Aggiungi Commento
Raise black pad to detach trackpad ribbon if not done in step 4.
  • Raise black pad to detach trackpad ribbon if not done in step 4.
  • (Completing this step according to the directions in step 4 reduces the potential for damage.)
Aggiungi Commento
Undo hard drive ribbon by lifting black clips upward. Undo (4.6 mm) screws that hold hard drive in place There may be only one screw of these screws, the one at bottom right. The upper position screw may already have been removed (The 4th red circle from the left in step 4)
  • Undo hard drive ribbon by lifting black clips upward.
  • Undo (4.6 mm) screws that hold hard drive in place
  • There may be only one screw of these screws, the one at bottom right. The upper position screw may already have been removed (The 4th red circle from the left in step 4)
Aggiungi Commento
Gently pull the hard drive to the left by the black plastic ribbon. Ease drive up on the left and then out. When re-inserting, use caution to ensure that the WiFi antenna cable (visible as a black loop below the disk in the 2nd photo) is not trapped under the leg of the drive encasing.
  • Gently pull the hard drive to the left by the black plastic ribbon. Ease drive up on the left and then out.
  • When re-inserting, use caution to ensure that the WiFi antenna cable (visible as a black loop below the disk in the 2nd photo) is not trapped under the leg of the drive encasing.
Aggiungi Commento
Lift the black clips using the plastic opening tool in order to detach the ribbon that connects the SD card module. Lift the black clips using the plastic opening tool in order to detach the ribbon that connects the SD card module.
  • Lift the black clips using the plastic opening tool in order to detach the ribbon that connects the SD card module.
Aggiungi Commento
Remove the wifi antenna connection using the plastic opening tool.
  • Remove the wifi antenna connection using the plastic opening tool.
Aggiungi Commento
Undo this screw, which holds the wifi component in place, using the Phillips head screwdriver. Undo this screw, which holds the wifi component in place, using the Phillips head screwdriver.
  • Undo this screw, which holds the wifi component in place, using the Phillips head screwdriver.
Aggiungi Commento
Pull the Wi-Fi component to the right, and then slightly upward and finally out to remove the Wi-Fi antenna.
  • Pull the Wi-Fi component to the right, and then slightly upward and finally out to remove the Wi-Fi antenna.
  • Move antenna cautiously to avoid damage.
Aggiungi Commento
Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool
  • Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool
Aggiungi Commento
Detach the Bluetooth wire located below the fan by gently pulling it upward. Detach the Bluetooth wire located below the fan by gently pulling it upward.
  • Detach the Bluetooth wire located below the fan by gently pulling it upward.
Aggiungi Commento
Detach the black structure connected to the input cables in the top right center of the motherboard. Detach the black structure connected to the input cables in the top right center of the motherboard.
  • Detach the black structure connected to the input cables in the top right center of the motherboard.
Aggiungi Commento
Remove the 3 (5.5 mm) screws holding the motherboard to the motherboard plastic frame and also remove the four screws surrounding the fan. Remove the 3 (5.5 mm) screws holding the motherboard to the motherboard plastic frame and also remove the four screws surrounding the fan.
  • Remove the 3 (5.5 mm) screws holding the motherboard to the motherboard plastic frame and also remove the four screws surrounding the fan.
Aggiungi Commento
Gently lift the motherboard and hold it so that the bottom of the board is exposed.
  • Gently lift the motherboard and hold it so that the bottom of the board is exposed.
Aggiungi Commento
Disconnect the cable attaching the motherboard to the fan. Disconnect the cable attaching the motherboard to the fan.
  • Disconnect the cable attaching the motherboard to the fan.
Aggiungi Commento
Remove two screws holding the fan and the brass frame to the motherboard. Remove two screws holding the fan and the brass frame to the motherboard. Remove two screws holding the fan and the brass frame to the motherboard.
  • Remove two screws holding the fan and the brass frame to the motherboard.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 78
Tutti i Tempi: 8,575
