Introduzione
The expansion pipe allows the angle of the parabolic dish to be adjusted in order to achieve maximum light focus on the cooker flat. The T-bar also supports the weight of the entire parabolic solar panels.
Strumenti
Parti
Nessuna parte richiesta.
Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side. Be sure the flat side of each tripod leg is facing toward the ground.
  • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
  • Be sure the flat side of each tripod leg is facing toward the ground.
Aggiungi Commento
Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
Aggiungi Commento
Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly. It does not matter which direction the 14mm bolt is inserted from.
  • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
  • It does not matter which direction the 14mm bolt is inserted from.
Aggiungi Commento
Conclusione
To disassemble your device, follow these instructions in reverse order.
Ashlie Reott
Membro da: 20/10/2013
328 Reputazione
3 Guide realizzate
Cal Poly, Team 4-30, Amido Fall 2013 Membro di Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 281
