Salta al contenuto principale
Apple TV 3rd Generation Power Supply Replacement
Cosa ti serve
  1. Apple TV 3rd Generation Power Supply Replacement, Snap-on Base: passo 1, immagine 1 di 1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Power Supply Replacement: passo 2, immagine 1 di 1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Power Supply Replacement, Logic Board: passo 3, immagine 1 di 1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Power Supply Replacement: passo 4, immagine 1 di 2 Apple TV 3rd Generation Power Supply Replacement: passo 4, immagine 2 di 2
    • Disconnect the power supply connector from the logic board with a spudger.
  5. Apple TV 3rd Generation Power Supply Replacement, Power Supply: passo 5, immagine 1 di 2 Apple TV 3rd Generation Power Supply Replacement, Power Supply: passo 5, immagine 2 di 2
    • Before you remove completely the power supply, unscrew the T5 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
Conclusione
Altre 14 persone hanno completato questa guida.
Vincent Monteil
Membro da: 07/06/13
6.975 Reputazione
19 Guide realizzate
11 Commenti
you forgot to add the power supply is held by 2 tiny torx screw
morpheuse - Replica
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
rcbakes30 - Replica
Where? I need on badly! Can you send me / Post here a link?
jakesterage -
please, and where could be find the part, the power supply for AppleTV 3rd generation?
foxy72 - Replica
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
ilichcorcegatreep - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 43
Tutti i Tempi: 19,943
