Introduzione
Removing the logic board is a very simple procedure. Hopefully you never have to do this to your Apple TV. Just a note... There is nothing wrong with my Apple TV. I made this guide for those that may need to use it one day. My Apple TV is still running well
Use a spudger to pry the bottom cover off the Apple TV. It may be necessary to use two spudgers (one to hold it open while you pry with the other one)
  • Use a spudger to pry the bottom cover off the Apple TV.
  • It may be necessary to use two spudgers (one to hold it open while you pry with the other one)
Aggiungi Commento
Carefully remove the bottom cover from the unit
  • Carefully remove the bottom cover from the unit
Aggiungi Commento
Remove the pink thermal pad. (I already removed mine) Remove the five philips #1 screws securing the heatsink and logic board to the upper casing.
  • Remove the pink thermal pad. (I already removed mine)
  • Remove the five philips #1 screws securing the heatsink and logic board to the upper casing.
Aggiungi Commento
Using a screwdriver (flathead) or a spudger, pull the power cable out of the logic board Now with a spudger or flathead screw driver, CAREFULLY remove the LED connector. Do this very carefully as this connector is extreme fragile, and easily damaged.
  • Using a screwdriver (flathead) or a spudger, pull the power cable out of the logic board
  • Now with a spudger or flathead screw driver, CAREFULLY remove the LED connector. Do this very carefully as this connector is extreme fragile, and easily damaged.
Aggiungi Commento
Use a flathead screwdriver or spudger to tilit the logic board to an angle so you can grab it with your hands Holding the logic board by it edges, lift it up slightly. And remove
  • Use a flathead screwdriver or spudger to tilit the logic board to an angle so you can grab it with your hands
  • Holding the logic board by it edges, lift it up slightly.
  • And remove
  • Thats all. The logic board has been removed. Just follow the steps (Step 1-5 in reverse to install the board)
Aggiungi Commento
The chip with the grease on is the Apple A4 chip. The thermal pad took the silkscreen off, so its hard to read. The The black ball surrounded by meta is the IR Remote sensor. In the third picture, the power connector and LED status connector are shown.
  • The chip with the grease on is the Apple A4 chip. The thermal pad took the silkscreen off, so its hard to read.
  • The The black ball surrounded by meta is the IR Remote sensor.
  • In the third picture, the power connector and LED status connector are shown.
Aggiungi Commento
HDMI Port Micro USB Port (used for diagnostics, and service)
  • HDMI Port
  • Micro USB Port (used for diagnostics, and service)
  • Digital TOS Link out (Optical Out)
  • Gigabit Ethernet
  • The second picture shows the thermal pads (pinkish white edge stuff) this keeps the components of the logic board cool and happy.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Nicholas Ouimet
Membro da: 16/10/2009
2.066 Reputazione
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 11,779
