Salta al contenuto principale
Apple TV 1st Generation AirPort Card Replacement
Cosa ti serve
  1. Apple TV 1st Generation AirPort Card Replacement, Lower Case: passo 1, immagine 1 di 1
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Apple TV 1st Generation AirPort Card Replacement: passo 2, immagine 1 di 1
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. Apple TV 1st Generation AirPort Card Replacement: passo 3, immagine 1 di 1
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. Apple TV 1st Generation AirPort Card Replacement: passo 4, immagine 1 di 2 Apple TV 1st Generation AirPort Card Replacement: passo 4, immagine 2 di 2
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
  5. Apple TV 1st Generation AirPort Card Replacement, AirPort Card: passo 5, immagine 1 di 1
    • Pry the AirPort antenna cables straight up from their sockets on the logic board.
  6. Apple TV 1st Generation AirPort Card Replacement: passo 6, immagine 1 di 1
    • Remove the single T8 Torx screw securing the AirPort card to the logic board.
  7. Apple TV 1st Generation AirPort Card Replacement: passo 7, immagine 1 di 1
    • Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
Conclusione
Altre 11 persone hanno completato questa guida.
ropel
Membro da: 11/11/09
113 Reputazione
2 Guide realizzate
Cal Poly, Team 18-5, Maness Fall 2009 Membro di Cal Poly, Team 18-5, Maness Fall 2009
CPSU-MANESS-F09S18G5
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 13,368
