Introduzione
Replacing the ADC cable. This cable provides connection to the computer, along with supplying power to the display.
Parti
Nessuna parte richiesta.
Lay the display facing down with the stand away from you. Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  • Lay the display facing down with the stand away from you.
  • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Aggiungi Commento
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
Aggiungi Commento
Rotate the display so the legs of the display are now facing you
  • Rotate the display so the legs of the display are now facing you
  • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
Aggiungi Commento
Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Aggiungi Commento
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Now locate and remove the lone screw holding the EMI shield to the display
  • Now locate and remove the lone screw holding the EMI shield to the display
Aggiungi Commento
Now that the screw has been removed, slide the panel towards your body and lift it out. You may need to remove the clear USB port cover to remove the metal EMI shield.
  • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
Aggiungi Commento
To remove the USB port, remove these four screws holding down the port and metal brackets.
  • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
Aggiungi Commento
Remove the cable from the logic board that is connecting the USB port.
  • Remove the cable from the logic board that is connecting the USB port.
Aggiungi Commento
Remove the USB port
  • Remove the USB port
Aggiungi Commento
Remove these four screws holding down the base of the swing arm to the display and remove it
  • Remove these four screws holding down the base of the swing arm to the display and remove it
Aggiungi Commento
Remove the four screws holding down the ADC cable to the display
  • Remove the four screws holding down the ADC cable to the display
Aggiungi Commento
Remove the three connections  that connects the ADC assembly to the logic board and screen
  • Remove the three connections that connects the ADC assembly to the logic board and screen
Aggiungi Commento
Remove and replace the ADC cable assembly.
  • Remove and replace the ADC cable assembly.
Aggiungi Commento
Conclusione
Andrew Tsao
Membro da: 19/01/2010
159 Reputazione
5 Guide realizzate
Cal Poly, Team 3-20, Maness Winter 2010 Membro di Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 663
