Salta al contenuto principale
Apple Powerbook 5300 Keyboard Replacement
Cosa ti serve
  1. Apple Powerbook 5300 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Keyboard Replacement: passo 3, immagine 1 di 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
Conclusione
Scott
Membro da: 04/26/11
155 Reputazione
5 Guide realizzate
Cal Poly, Team 25-30, Garner Spring 2011 Membro di Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,559
