Introduzione
To replace the hard-drive, one must first remove the keyboard and RAM to be ready to remove the hard drive from the computer.
Parti
Nessuna parte richiesta.
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
  • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
  • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Aggiungi Commento
Pull the keyboard ribbon vertically from the logic board to release connection.
  • Pull the keyboard ribbon vertically from the logic board to release connection.
  • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
  • Remove battery and CD/DVD drives before proceeding any further.
Aggiungi Commento
Your computer should look approximately like this.
  • Your computer should look approximately like this.
Aggiungi Commento
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
  • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
  • Lift the heat shield up and toward you.
Aggiungi Commento
Pull the PRAM battery cable vertically upward to disconnect it.
  • Pull the PRAM battery cable vertically upward to disconnect it.
  • Remove the battery by pulling up and to the left.
Aggiungi Commento
Remove the two T8 Torx screws that attach the heat sink to the processor.
  • Remove the two T8 Torx screws that attach the heat sink to the processor.
  • Remove the long silver Phillips #1 screw from the heat sink.
Aggiungi Commento
Lift up the heat sink unit from the left side and remove.
  • Lift up the heat sink unit from the left side and remove.
Aggiungi Commento
Lift the processor on the right side and pull directly up.
  • Lift the processor on the right side and pull directly up.
  • The RAM chips should be in the slots on the processor.
Aggiungi Commento
After removing the RAM, your laptop should now look like this.
  • After removing the RAM, your laptop should now look like this.
Aggiungi Commento
Locate the orange tab, which should be just left of the hard-drive.
  • Locate the orange tab, which should be just left of the hard-drive.
  • You must disconnect this orange tab from the logic board to enable the next step.
  • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
Aggiungi Commento
Grab the plastic strip shown here and gently remove, pulling up and left.
  • Grab the plastic strip shown here and gently remove, pulling up and left.
  • Pull left to avoid the hard drive catching the casing.
Aggiungi Commento
Once you have removed the hard-drive, your laptop should like this.
  • Once you have removed the hard-drive, your laptop should like this.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Kevin Keegan
Membro da: 19/04/2011
67 Reputazione
2 Guide realizzate
Cal Poly, Team 4-2, Regan Spring 2011 Membro di Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,089
