Introduzione
This repair will need:
A T-8 or T-6 Torx Screwdriver.
Parti
Nessuna parte richiesta.
Turn computer over. Remove battery expansion cover and battery.
  • Turn computer over.
  • Remove battery expansion cover and battery.
Aggiungi Commento
With monitor hinge at the bottom, remove the two top center screws.
  • With monitor hinge at the bottom, remove the two top center screws.
Not necessary for RAM, hard drive, or CPU replacement.
Miles Raymond - Replica
The Screws are T8!
Willy Kaiser - Replica
Remove top left and top right screws.
  • Remove top left and top right screws.
Also not necessary for RAM, hard drive, or CPU replacement.
Remove middle left and middle right screws.
  • Remove middle left and middle right screws.
Aggiungi Commento
Open computer kickstands.
  • Open computer kickstands.
  • Remove screws underneath each kickstand.
Again not necessary for RAM, hard drive, or CPU replacement.
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Lift keyboard from bottom and take out of shell.
  • Lift keyboard from bottom and take out of shell.
Aggiungi Commento
Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool. Removing both ribbon cables from the motherboard will leave the clamps like so. From here you can access the logic board, hard drive, and floppy drive.
  • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
  • Removing both ribbon cables from the motherboard will leave the clamps like so.
  • From here you can access the logic board, hard drive, and floppy drive.
Aggiungi Commento
Remove the plastic panel on the bottom of the LCD Screen.
  • Remove the plastic panel on the bottom of the LCD Screen.
Not necessary for RAM, hard drive, or CPU replacement. This may also cause excess wear on the already-fragile plastic pieces that hold it in.
Open panel on back of the device. Remove 2 T8 torque screws.
  • Open panel on back of the device. Remove 2 T8 torque screws.
Aggiungi Commento
Remove the plastic panel underneath the LCD Screen.
  • Remove the plastic panel underneath the LCD Screen.
Aggiungi Commento
Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
  • Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
Aggiungi Commento
Remove the logic board protection plate.
  • Remove the logic board protection plate.
Aggiungi Commento
Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
  • Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
Beware: there might be a little plastic 'bridge' piece that goes around the memory connector (mine had one that isn't in this guide) which needs to be removed first before removing the RAM card. It was both difficult to remove and fragile (broke on one side during removal).
Once the old Memory board is removed, replace it with the new Memory board.
  • Once the old Memory board is removed, replace it with the new Memory board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Tyler
Membro da: 10/04/2011
129 Reputazione
2 Guide realizzate
Cal Poly, Team 20-66, Walters Spring 2011 Membro di Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,183
