Introduzione
At some point the internal battery may run out of energy and need to be replaced, this guide is here to help you do this. This process and is quite simple and straight forward with the right tools. A 3V CR2450HR battery will be needed before starting.
The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
  • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
  • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
This is where you would use the opening tool. It’s the perfect tool to lift the rubber base around the metal lip and then pull with your fingers.
Eddie de la Rosa - Replica
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Aggiungi Commento
Lift up the back case from the perforated edge to remove it.
  • Lift up the back case from the perforated edge to remove it.
Aggiungi Commento
Remove logic board and metal casing from outer case by prying from one side using a spudger.
  • Remove logic board and metal casing from outer case by prying from one side using a spudger.
I have found it easier to lift from the side with the Ethernet ports. When putting back together watch that the three WI-FI antennas don’t get snagged against the case as your putting back.
Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
Aggiungi Commento
Carefully push back the three metal tabs with your fingers on the sides of metal case.
  • Carefully push back the three metal tabs with your fingers on the sides of metal case.
Aggiungi Commento
Carefully pull the metal case away from the logic board.
  • Carefully pull the metal case away from the logic board.
Aggiungi Commento
Gently slide out the battery with a small narrow tool such as a spudger. Insert a new 3V CR2450HR.
  • Gently slide out the battery with a small narrow tool such as a spudger. Insert a new 3V CR2450HR.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Zak
Membro da: 23/09/2014
507 Reputazione
4 Guide realizzate
USF Tampa, Team 12-4, Blackwell Fall 2014 Membro di USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 60
Tutti i Tempi: 2,638
