Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
Aggiungi Commento
Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
Aggiungi Commento
Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing. Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
Aggiungi Commento
Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
Aggiungi Commento
Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
  • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
  • To remove the AirPort card, gently pull the plastic tab horizontally.
Aggiungi Commento
Locate and remove the three 5.0mm phillips screws from the heat sink.
  • Locate and remove the three 5.0mm phillips screws from the heat sink.
  • Lift to remove the heat sink from the motherboard.
Aggiungi Commento
Locate and remove the five 7.5mm phillips screws from the motherboard. Lift and separate the motherboard from the bottom metal casing.
  • Locate and remove the five 7.5mm phillips screws from the motherboard.
  • Lift and separate the motherboard from the bottom metal casing.
  • There will be a loose hexagonal female screw extender under the motherboard.
Aggiungi Commento
Desolder the six connections located under the USB. Refer to How To Solder and Desolder Connections for soldering techniques.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Michael Garcia
Membro da: 12/10/2011
369 Reputazione
5 Guide realizzate
Cal Poly, Team 17-15, Regan Fall 2011 Membro di Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,698
