Salta al contenuto principale
Apple AirPort Extreme Model A1034 Motherboard Replacement
Cosa ti serve
  1. Apple AirPort Extreme Model A1034 Motherboard Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 3, immagine 1 di 2 Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 3, immagine 2 di 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 6, immagine 1 di 1
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 7, immagine 1 di 1
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 8, immagine 1 di 2 Apple AirPort Extreme Model A1034 Motherboard Replacement: passo 8, immagine 2 di 2
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-15, Regan Fall 2011 Membro di Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,971
